Motor Change
camper
Need advise please-- I bought 1999 Bennington 20 Ft pontoon, the motor and battery are gone. It originally had 40 horse Mercury outboard,would like to upgrade to 75 horse 4-stroke, any idea what would have to be changed to do this and possible cost.
Thanks in advance, Camper
D
DJ
Guest
Re: Motor Change
If you stay with Mercury, your controls should work.
Other than that, most likely just the price of the engine.
BTW, we have a 75 Four Stroke on a similar size Starcraft and love it.
tashasdaddy
Re: Motor Change
if i were to change mine, i would go 4 stroke, just due to noise levels.
camper
Re: Motor Change
Thanks for the replys. I plan on buying a 07 or 08 4-stroke 75 HP Merc to replace the 1999 40HP Merc that was original. Someone mentioned a different control box and wiring harness, does anyone know anything about that? Also any ideas about a good prop? Thank in advance-- Camper
tashasdaddy
Re: Motor Change
you will have to ask whether the controls are compatible in the merc outboard forum, and the prop in the prop forum.
