Motor dies in neutral
Albaj13
Boat: 17’ Larson 174 sei
3.0 liter merc cruiser alpha one I/o
Est distributor
Boat dies in neutral and have to constantly apply constant throttle(small amounts) in order to keep running. Runs and shifts good . Sounds like it’s getting full power . Unfamiliar w carbon stuff . Need help
ROY WILLIAMS
Est distributor
inspect the switch ignition gear switch use the throttle handle fwd neutral rev ... the gear cable / switch cable gear / adjusted it on the top of the engine cable throttle .. you tube ....
