Re: Motor floods at idle when trimmed all the way down
Lets try to take this one point at a time, you have given us some good info now. Was this shop a Mercury dealer? Yes, with the compression figures it had some internal problems, anything from stuck rings to scored cyl. they opted for a rebore. so lets start there.
1. what was the engine taken in for orginally?
2. the fact that they changed the trigger and switch box in a rebuild shows that they are parts changes not mechanics (someone grasping at straws)
3. the spark advance thing is less than nornal at idle you are running at 4 to 8 degrees spark, that is advanced to 27 degrees at WOT. (so if the timing is off at either end it is because the engine needs to be synchronizined, which is a norrnal part of an rebuild)
3 there are no new reed block spec. and when aligned properly on assembly no chamfering is needed
4. if bored to .040 then they had to use wisco pistion which require special fitting and break in.(was that done correctly)
5 both boring and resleeveing are common pratices in service shops and should give you like new running when done properly
6. the amt. of compession in a 2 cycle engine is not as important as it being equal (120 is wonderful and all compression is reliant on the fuel oil mix the more oil the more compression)
7. if the crankcases are mismatched, why didn't the problem show before and why didn't they notice it on teardown ( if the crankcases are leaking they can be ck easily by spraying with WD 40 or carb cleaner)
8. the hard starting and the poor idle still point at unseated rings (especially if every thing on the outside has been setup right) the only other thing that gives those problems would be bad reeds which should have been checked on assembly
8. even if it sounds like I think the shop is not the best service shop in the world that may not be true. We all make mistakes and have worked in shop with less that quialfied people. This shop is showing they are concerned by not charging labor (I bet you would rather paid the labor and had a properly running engine) but they toke the job and if they can't repair it they should either send it out or offer or pay to get it right. We got into a mess back in the early 70s on a 115 that was were simular, had to get a factory rep to look at it when he said it was not bored properly we said BS and he said if it don't fix it I will pay the parts and labor so we had it done by a differant machine shop and it ran great so we ate the rebore and learned anouther lesson.
Sorry for being so long winded--Bob
