2008 foot-operated motor won't shut off no matter what position the 3 way pedal toggle switch is in or even if the rotary speed dial switch is in the off position. Model number 950010200 and serial number 9B397606. Any ideas? Thanks in advance.
I need to purchase a digital volt meter. Both the 3 position switch and the foot push switch are wired in parallel before the 5 position rotary speed switch. Power then goes from the 5 position rotary switch directly to the motor. Even if the first 2 switches were shorted out why would the motor run if the final speed switch is in the off position?
