motorvator
- Jun 18, 2005
- 47
Bought a 1990 60 hp Evinrude a month ago. Was missing a few small parts. Got all the parts installed. Fired it up for the first time today. Sounded like it was only running on 2 cylinders. Pulled the plugs and #1 cylinder wasn't firing. Coil checked good. Plug wire was not conducting. Replaced plug wire. Fired it up, sounded good as long as I held the choke in. Then it sneezes out the #1 carb and looses rpm's. Checked the plugs again and #3 looks like it isn't firing all the time (wet). Took the plug wire apart and cleaned it. Still won't idle (cough and dies). I've got the OMC manuall for this motor. Says a lean condition will make it sneeze through the carb. Any suggestions as to what I should try next? This motor has very low hours on it. I'm going to check the compression next. I'll post what I get.
