Motor has no spark. 95 force 90 hp
fish reaper
I have tested my coils an the primary show a dead short but the secondary test within spec is this my CDI
pnwboat
Forgot to menton....Before you go messing with the stator, make sure the Kill Switch is not shorted. This will kill the ignition system. The Kill Switch Lanyard needs to be connected, or the "RUN"/"STOP" switch needs to be set to the "RUN" position for the ignition system to work.
jerryjerry05
outboardignitiondotcom has test procedures for your motor.
​Do a compression test to see if the general health is good.
Then if one coil is suspect? Try swapping it with one of the other coils.
