MassillonBuckeye
- Jul 26, 2010
- 400
1978 Merc 70HP Thunderbolt ser#4827***. Have had it on the water twice. Have had it idling in the driveway a few more times than that. Starts and idles like a dream. On the water, I get to about 1500 RPM I'd estimate and can't get any more OOMPH out of her. Just small "bursts". RPMs and the boat jumps a bit. When its dogging, you can hear the carbs opening, as the exhaust gets a little throatier, but not more power. Classic case of fuel starvation?
The only problem I have with that is it has run GREAT twice now. Once each trip. No rhyme or reason other than the second time I had increased the throttle fairly slowly and it just keep gaining power. COOL! Popped up on a plane and sounded real nice. We ran for about 45 sec or so, then I brought it to a stop. To have it be a dog foer the rest of the day. First trip on the water, at a seemingnly random attempt, it throttled up with power, but I was in a no wake zone so I couldn't do much about it. That time it seemed to last a bit longer. When I brought it home the first night, I opened it up to find this:
I thought EUREKA! We found er! And proceeded to remove the bolts and washers holding and crimping that fuel line... Someone had ran the fuel line between those bolts with washers and that piece of rubber holding it down.. Genius!! And also thought to myself YOU BIG DUMMY for even taking it out like that. But anyway, fast forward 2 days to seatest #2 and I have the same results. So it wasn't that crimped 1/4 fuel hose. Like I said earlier, I'm in the process of rebuilding the carbs(looking for the rebuild kits), cutting in mercury quick disconnect fittings and replacing the leaky primer bulb then we'll go from there. My question is, if the carbs were gummed up, how could it run great those two times out of the blue? Anyone else experience this?
