Re: Motor hasn't been started in 4years. What steps are necessary before trying
Zacbink<br /><br />If you just want to see if it will crank put some new gas and oil and a hot battery and go to it. You might want to put a little pre mix in a squirt bottle to spray into the carbs. If it cranks I wouldn't run it long at all. Then you probably will want new plugs, change the gear oil, rebuild the water pump, carbs, and maybe the fuel pump. If it won't crank then the fun begins..
