Hey everyone,
I recently bought a Valiant D380 RIB boat along with a Yamaha F20 outboard motor. Since this is my first boat, you can say that I do not know a lot about boats. Because of this I had to read my motor manual thoroughly. I noticed something when I mounted the motor on the boat. It sits too low. The anti-cavitation plate is around 2" lower than the lowest V point of the boat. I've driven the boat only once and I noticed that on lower speeds it does not run well (like it doesn't have power), and on higher speeds it tends to push the nose downwards. The tilt angle was on the lowest point. I cannot mount the engine higher(maybe just a 1/2"), because the front mounting screws can't go any higher on the transom.
My question is this: Can I mount the motor only with the mounting holes on the transom? Will it hold? Because otherwise I will have to do some major modification on the transom in order to mount the motor higher?
