suneshop
- Mar 14, 2013
- 56
I have a new Crest ll cp3 2755 lbs 3 pontoons with the 250 optimax pro xs.1.75 gear.Lifting strakes.The prop I have now is QA1912X17P. The motor is set one bolt hole up from the lowest setting. WOT is 40 mph 3 people @6000 rpm. That is the same speed that I got with the 15" pitch prop that came with the boat @6000 rpm.It will only run trimmed all the way down any trim up causes the rpm's to shoot up. With the 15" prop it hit the rev limiter 6200 rpm still 40 mph these speeds are with a GPS. It also starts to cavitate when running 5500 rpm and trying to turn.Wondering if the motor is set @ the right height or is it a prop problem.
