Motor issue need help ASAP for Commander
dlaxdal
My Mercury 1993 115 HP 2+2 starts fine and then when I get up to full throttle for about 40 seconds the motor dies right off then I have to restart and go thru process again. Any thoughts.
Thx
JB
Re: Motor issue need help ASAP for Commander
Sounds like a restricted fuel supply. Look for a pinched fuel line.
dlaxdal
would it be the bulb or connector to motor. Lines look good
Fuel Pump?
japayton6
Check under fuel connector, fuel lines comming apart from the inside out has been common problem. hope this helps
japayton6
yes pull it off the hose and look in line and fitting
