motor jerks on startup
stack08
125 force outboard..1990
I noticed when i start my motor that it jerks a bit and sometimes shuts off..then i restart it and let it sit for a min or two in idle then it runs fine doesn't jerk anymore..is this normal till it warms up a bit...it might do this a couple of times but then stays good...
roscoe
Re: motor jerks on startup
semi normal.
Make sure you are pumping the fuel primer bulb till firm, before starting, it may help.
stack08
ok I will check that the bulb is hard before starting and see how that works because other than that it works fine.
Thanks
stack08
Besides the buld what else could it be?
What might I be able to do to maybe help to this...maybe clean something?
This is only on cold starts then it seems ok if I go put shut off then after a while when stating it might do it one or two times.....
timdan94
I have a 1985 85 hp that idles rough if you bring the throttle to idle right after start up so I leave it revved up a little for about 15-30 seconds then its fine
maxum247
If the engine idle, rpm is set correctly, try backing the idle screw on each carburetor out 1/8 of a turn and see if that improves the kicking during warm up, doing this allows the engine to run a little richer.
Notice the setting of the idle screws on the carburetors before adjusting them in case you need to set them back where they were originally.
stack08
ok i'll try that....i gotta see what screw that is and where it is?
