I have a 1983 Johnson 115hp V4. I notice a wobble in the motor and it will move back and forth and has gotten a little worse with each use. I took it to the boat shop to have it repaired and was told the upper motor mount was broke. Just wondering if 200 dollars was reasonable to fix it and if 100 dollars was reasonable to replace the lower unit shaft seals. Thanks for you time.
