I have a 1984 90hp inline 6cylinder merc.<br />new carb kits new fuel pump kit<br />the motor starts fine cold but after running for a while or after running at slower trolling speeds the motor will not come back up to full RPM seems to hold up at 1500-2000 RPM.Doen't help to squeeze fuel bulb when this is happening.<br /><br />I noticed when I was running it in the yard that i had a good stream of water coming out of the return line from the motor head. Now below the motor housing on the top of the lower leg there are two ports, that also have exaust gasses coming out of them with a little bit of water however the one didn't appear to have any exhaust gas and absolutely no water coming out of it.<br /><br />Could this be causing the motor to over heat?
