Hi all, I bought this boat with a 45 hp chrysler, I believe it was made in the early eighties. Anyhow I got it a new battery and it started right up. (boat hasn't been run in two years). Well after running it a couple minutes I gave it some throttle and the #@$@muffs slipped off and hit the prop and it conked out. Now it won't start. Is there a kill switch on this motor somewhere that I don't know about? Just for the record I also was using the same gas that came with the boat, which after reading a couple of posts in this forum I realize I shouldn't have but that is water under the bridge now. I took the plugs out and they were wet with gas so I dried them and cranked it a few times to blow any excess gas out but it didn't help. I tried starting fluid to see if it would at least fire but nothing which leads me to believe that there may be a kill switch and i don't know where to look. Any advice is greatly appreciated. <br /><br />Rich M.
