motor removeal
macojoe
I have a 1992 Henry O' with a 1992 120 Johnson, The problem is I have removed everythnig and the motor is still stuck to the boat???<br />The bolts have the nuts removed on the out side so motor should come off?? The bolts are stuck in the transom and will not turn or come out??<br />I am scared to hammer anything or heat things up without asking for some help!<br /><br />Thanks for your help!!
D
DJ
Guest
Re: motor removeal
macojoe,<br /><br />Most likely, just the sealer used is holding it.<br /><br />Do not be afraid to drive the bolts out (four) with a center punch.
