motor repair
snapperbait
Re: motor repair
The minimum compressiom per cylinder should be no less than 100 psi. The important issue is that all cylinders are within 15psi of each other.. :)
dimitry
Re: motor repair
What is the range of "normal" values of the compression?<br />The measurement on the motor that I was planning to buy shows 110~120 psi. Is it too close to the minimum?
rickdb1boat
Re: motor repair
Depends on the age of the Motor and other factors, but anywhere around 100-125, within 15PSI of each other is fine.
