jdogonhood
- Jun 26, 2011
- 25
Replaced cracked block with block from suv. Old motor model # is 432APRGDP, which is Right-ward propeller rotation. I missed this little detail. The new motor turns counter-clockwise/impeller turns counter-clockwise when viewed from the rear and the flywheel turns counter-clockwise when viewed from the back. Can anyone enlighten me about this and is this going to work? Everything marine was changed except the long-block's. The marine starter is the same and starts the engine, Why? Should't the starter be rightward rotation turning the motor over the other direction? any insight is much appreciated. I cannot remember the actual direction the old marine engine turned. Wouldn't the water pump work circulate the wrong way as well?
