Re: motor runnin, prop not???
Speaking generically; check that the shift mechanism is operating.check the cable hookup.
There is a coupling between the motor and the drive. There is slim chance it has failed.
It won't test shift right unless the motor is running or you rotate the prop to help it mesh.
