Your Lower Shift Cable is Junk.......<br />Replace it.........<br />when i put it in reverse the motor dies immediately.it idles fine goes forward fine
This is a Fuel Issue..........<br />Start with Filters.....<br />Probably the Accelerator Pump is Worn Also..........it does stumble a little when taking off if i give it alot of throttle fast.
