CaptainSteve75
- Mar 15, 2010
- 23
Yamaha 99 S200TXRX
The chain of events that occur are as follows
1. Clean and rebuilt carbs with kit...New Spark Plugs...New Mech. Thermostats.
2. Tested Motor using portable tank with fresh gas. No issues with boat Gas Line, Bulb, fuel filter, and water separator.
3. Resistance test (engine off, Ambient temp of 68-70 degrees) was conducted and all results were in range per manual, Thermo switches, Thermometer, Oil Float sw 1, 2, and 3, CPS (gap fixed), Both sides of Pulser out of top and bottom of CDI, Lighting coil, Stator, Rectifier, Ignition coil.
4. Spark (Blue strong) and compression test within range per manual.
5. Wiring: Followed every wire from components to CDI from CDI to Wire Harness to ensure proper connection. Found couple of wire loose not making proper contact and repaired them.
Issue at hand when engine reaches above 2500 - 3000 RPMs the engine starts to surge http://www.youtube.com/watch?v=RhECQvyJylQ
It goes up to 5000 rpms then down to 3000 then down to 1000 and back up to 3000 with remote at WOT.
The power is there...but there is definitely something that is holding it back...Some of you mention something about lose the pulser coil and it dumps 4 cylinders...Is there some kind of dianostic tool I can use to further troubleshoot this problem.
Also I have not done any load test while the enigine is running I was hoping I can find a dianostic tool. My guess is that one of the pulsers or the stator which mimics fuel problem which may be on its way out.
