I have a 130hp Chrysler outboard. Over the 4th of July weekend I had a leak start on the fuel bowl of my carb. I ordered new kits. Very carefully I removed 1 carb at a time. Not to change anything on the linkage. I replaced the needle and seats set float hieght and installed new bowl gaskets. Also replaced the fuel pump diaphram. The boat has always been a little lazy until the rpm's come up. Now it has a bad stumble. The idle adjust screws where set a 3/4 turns out. The kit says to set them at 1 1/2 turns out. Would this cause my problem? Motor runs fine after the rpm's come up. Idles good also. But it is hard to get a ski or tube up on plane. <br />Thanks Jerry
