Re: Motor stutters at high end speed [video]
its 100% nothing to do with the propeller.
i dont care what they say about spun hubs, if was the hub spiing then you would get higher revs just not go any faster.
this is a fuel issue.
the fuel pump could need a rebuild kit,yes it could be that,but i would sooner go for high speed jet blocked or dirt in the
carb bowl and float setting not right.
cab is a easy thing to do yourself, it realy aint hard one to do at home.
ive got those of and cleaned in not time they ae a easy fix to be honest.
Do get yourself an inline filter as well, thiose cheap throw away ones you can see through the plastic are good enough and very cheap
they can save lots of rubbish getting in the carbs.
also when you store it or put it away after use, do you run it out of juice in the upright position ?
or do you just switch it off ?
if you just turn it off how long is it then left for before used again ? as it can be fuel gummed up in the carbs if left a while.
modern petrol dont like to sit around too long before turning to varnish and gum in a static place.
just a few thoughts on it..
by the way what size prop have you ordered for it ?
and what size was on it when running in the vid ?
phill
