Motor swap question
Status
Not open for further replies.
viper122
I have a 3.0 mercruiser I'm thinking of swapping, serial 0L319125. It's currently setup with a mercruiser 120 outdrive. The outdrive is in good condition so i want to find a motor replacement for it; what options do I have for the engine that would be compatible with this outdrive, in the event I can't find an exact replacement? Obviously I assume it would have to be another mercruiser engine but as far as year/hp/liter I wish to know what my options are, if any. Thanks!
cr2k
Re: Motor swap question
2.4 or 3.0 are the 2 4 cyl choices you have with the 2.4 being lower HP. Although these LOOK like the GM Iron Duke 4 cyl they are in fact a marinized industrial engine. Any thing in 6 or 8 Cyl would require drive change to get proper gear ratio.
Ayuh,... The 2.5ls are few, 'n far between...
Like I said in your Other thread,...
Get another 3.0l....
About any of 'em from the late 60s to current production are adaptable at the long block configuration...
latunguley
Now above here its states again Commercial motor 3.0???? Comercial motor??? Are we talking the old school Grumman olson Allied Industries 4 cylinder comercial motor/ USPS Mail truck 4 cylinder comercial motor? ? ? Or is it just terminology for MARINE Engine? Please someone shed some lite on me. I have a 99 Bayliner Capri 1850 LS Bowrider with a very seized up 3.0 engine. I need a quick swap fix. I welcome anyones feedback here. I really need a shoe string budget motor swap here. Would like to have this boat running by the 4th Of July 2011???? Or soon there after?? Thanks in advance
Ayuh,... As in the sense that it's Never been used in an automobile...
Status
