Re: Motor turns to slow to start 1989 50hp force
Very common problem, LH, very commonly caused by hidden corrosion in connections of battery cables.
Take both cables off, scrub the connectors shiny and reconnect. Short cables from solenoid to starter also are suspect.
Other possibles:
Bad battery. Showing full charge is testimony not under oath. . . er. . .load. Test with hydrometer.
Bad starter. Test by jumping battery terminals direct to starter motor.
Bad solenoid. Test by jumping past solenoid direct to starter.
Good luck. Let us know what you find.
