Motor want start
jlpbhm
I have a 40 horse power force that will not start it was running and I had to switch gas tanks and since then it will not start When I prime the ball at the tank and try to start it fuel runs out of the motor if anyone can help please let me know.<br /> Thaks J P
roscoe
Re: Motor want start
Where is the gas leaking from?<br />Broken gas line?<br />Fuel pump?<br />Carb?
jlpbhm
I can not see where the fuel is coming from it acts like the motor is flooded but when I let it set it does nothing and know i have no power on the nothing electric will work
eurolarva
can you post your model number? Have you tried charging your battery with a charger and then reconnecting to the motor? When you squeeze the primer ball what happens? Will it get stiff or does it stay soft? When you squeeze the primer does it want to stay compressed or does it reinflate?<br />Do you have an inline fuse going to your electronics? Could this be blown
