Motor will not rev past 3k rpm
lindsey
I was in the boat yesterday it was running fine all day then it started hesitating when i would get on step up to wide open throtle. Then it cleared up.I then slowed the boat to a stop checked my fuel tank to see if i was running out gas everything was good.Try to get back up on step and the motor would not go past 3k rpm. The motor idles fine starts right up and will rev up fine with the cold start lever. Its a 1973 evin 85 hp.
jonesg
Re: Motor will not rev past 3k rpm
Try choking it, if that gets the rpm up (in gear not in neutral) then you might think about rebuilding carbs with new carb kits,
and do you have a water seperator, we need them now.
lindsey
I tried that trick with no luck. The carbs where just rebuilt and all the fuel lines replaced.link and sinc where done to recentily. I'm thinking maybe water in the fuel or trash in the high speed jets because it idles fine starts on the first crank and i can rev it up with the cold start lever with no problem.
steelespike
Did it cut out like you turned a switch?Maybe your loosing a cylinder.Check the spark.
honald112
I was having a similar issue on my 75 115 Rude. What was happening was the 1 and 3 coils would cut out. It would start fine and the warm up bar would bring it to 4,000 rpms, but in gear i couldn't get over 3000. I cleaned up the grounds on the coils and also the connections in the power pack. Make sure your battery is good too.
jonesg
You mean it will rev up with no load?
could be a cyl not firing.
Draw some fuel and leave in a glass, watch for water seperation after a couple of minutes.
lindsey
well i found the problem.it was a very tiny piece of rubber from one of the fuel lines blocking one of the high speed jets go figure.
jonesg
Thats all it takes to melt a piston too if you run it all day WOT.
It pays bigtime not to assume anything.
