Re: Motor wont start in the lake?
Im a bit confused now, which isnt hard to do by the way, lol
Originally you said that it wouldnt turn over, which is a quite different problem than not starting, but turning over.
To answer your question, yes starting on the muffs, and starting on the lake under water are quite different. Just because it will start on the muffs does not mean that it will start on the lake. Much easier to start on the muffs without any backpressure on the exhaust. Tell him to check for spark, to ensure it is properly firing on all cylinders. Depending on what motor we are talking about here will determine the distance the spark should jump with a bright blue ZAP!! on an inline tester.
When it is not starting, follow the steps provided in the FAQ entitled "Outboard Wont Start" and let us know what you find.
