My Mercury 500 50 HP Four was leaking oil from the lower unit so I replaced the water pump prop and all of the water pump gaskets. Now the motor starts fine when I put on the muffs. But when I took it out to the water it wouldn't start. The engine crank but won't start. I took it back home and put the muffs back on and it fires right up on the first try. I also took a big bucket fill with water and submerged the entire lower unit into the bucket and then turn the key and the motor also start up fine. So, my question is why it wouldn't start when I took it out to the water? Anyone has any advice or idea what might be the issue? Thanks in advance.
