motor wont start
izuizme
1976 Mercury 500-50hp serial #4418860 Ran fine last season.After this season's 1st.run took boat home to flush motor,& it will not start.So I replaced(4)old coils,with (4)new ones(I noticed a slight difference in the replacement coils, they lack a thin ground wire on the backside).Inspected & cleaned carbs. Have spark on all plugs.Compression on all cylinders is (110)psi.I tried a shot of WD 30 as advised by a member nothing ...What's the next trouble shooting step?? :confused:
lastout
Re: motor wont start
fuel would be the next thing. try some starting fluid in the carbs. if it fires then you may have a fuel problem. inspect the hose, filter, and replace the primer bulb. its the cheapst start to finding the problem.
izuizme
I tried that an 2hrs ago using WD40,not even a hiccup..!!
rjarreau
I AM NOT A MECHANIC BUT I KNOW A REALLY GREAT SITE IN HELPING WITH THOSE OLDER MERC'S THERE IS A NEWSGROUP THAT ALL THE PEOPLE ARE MECHANICS AND ARE SURE TO HELP YOU WITH YOUR WOES JUST FOLLOW THESE INSTRUCTIONS AND WILL BE VERY HAPPY WITH ALL THE HELP THESE GUYS WILL DO FOR YOU. THEY HAVE HELPED ME WITH MY OLD MERC. FROM ALL SORTS OF TROUBLES AND THEY ALSO SELL GOOD USED PARTS ON EBAY !!!<br /><br /> Also, there is an online discussion group (newsgroup) dedicated to inline 6's care and feeding! The NNTP server is: news.kraits.org and the newsgroup is: bigweek.mercury-inlines. In Outlook Express use: tools/accounts/add/news and then follow the prompts to join us there! See my "Me" page for more info!
foxjohnc03
First of all, NEVER use starting fluid on an outboard motor. It does not have the lubricating characteristics that Wd-40 or 50-1 premix has. If you got the engine running on starting fluid it would greatly increase the liklihood of damaging rings and cylinder walls. It is also not good for the bearings. Get a mist bottle and fill it with 50-1 premix. As far as the starting problem goes, make sure that you correctly hooked up all of the wires to the coils and power source. Even though the plugs spark it might not be strong enough to start the engine.
Walker
WD40 isn't any good as a starter spray anymore since the too out the propane as the propellant. It still works pretty good on diesels though.
roscoe
WD-40's current formula will not burn. THe old formula used propane as a propellant. <br /><br />Like John said, get a sqirt bottle with premix and spritz it in the carb.
izuizme
Thanks for your help Guys, I will try the 50:1 spray method in the carb when I get home from work
izuizme
At last,LASTOUT thank U I tried the starter <br />fluid and it turned over just fine. Now I guess I'll have to rebuild the entire fuel system...!!
