I have a older motorguide pro series 75# 24v trolling motor. My plug and receptacle need replaced so while, I'm getting ready for that, I thought I would go ahead and check all the wiring out and make sure everything is how it's suppose to be.
After looking over everything and doing a bunch of research, I'm flat out confused,
I have two batteries with 4 wires going to the switch with three going to the receptacle. My trolling motor only has two wires (red/black) with the plug having three. The previous owner had cut the third wire from the plug (orange) and taped it. My new plug/rec both have two wires, so I'm not quite sure what needs done there.
The orange wire on there now isn't being used for anything so I'm assuming I would just hook it up into the same terminals but just take the orange wire out that goes from switch to receptacle.
Check out my drawing and pictures, and let me know if everything looks right. Thanks!
