Your boat has two batteries - - one for the engine and one for the trolling motor. The engine probably charges only the starting battery so a separate plug-in type battery charger was given to you. The 3/5 means the charger has two outouts. One is rated at 3 amps and the other at 5 amps. Connect the 3 amp to the start battery and the 5 amp to the trollung motor battery.
