motorguide laser
phydoux35
just got a used boat that has a motorguide laser on it w/wireless foot cont. do not know how to operate it pre owner did not use it knows nothing about it. tried factory web site ,no good
18rabbit
Re: motorguide laser
Hi Fido. Welcome to the forum. :) <br /><br />I have no experience with the product you are asking about. Took a quick look at Motogruide’s website and found:<br /><br />[Products] -> [Motogruide Trolling Motors]-> [Catalog and Manuals]<br /><br />Maybe the info is in there? A cursory look didn’t find anything about ‘lasers’.
phydoux35
18rabbit, thanks, i already looked there likewise no help only 2005 stuff
Silvertip
The Lazer is an RF controlled motor much like the MinnKota Co-pilot. The foot pedal is essentially a radio transmitter. When you step on one of the buttons, a signal is sent to the head of the trolling motor where it is interpreted and the appropriate function is activated. Left, Right, Stop/speed, Hi bypass and constant on are all controlled by the pedal. Since the pedal is a transmitter, it requires a battery. I believe it takes a nine volt battery. Most of these were 24 Volt units so you need two deep cycle batteries.
phydoux35
upinsmoke, all true 2 new deep cycle new 9 volt in transmitter when you turn on power on light &function light comes on try to do any other function kills power have checked connections & made sure batteries were up
Silvertip
Sounds like it needs to be seen by a trolling motor doctor.
