motorguide VS Minkota
BIGcarpy50
What do you have to say...looking for a bow mount motor..which brand do you have and anything to think about in terms of differences.
John_S
Re: motorguide VS Minkota
You will generally get, "I have owned X and happy or what problems that they have had with X." To me, MK or MG is just a Ford/Chevy discussion. Focus on what type and features you may want or use, then see what options you have on brands and models.
- Transom VS Bow
- Set speeds VS Variable
- Shaft length needed
- Lbs Thrust needed (which drives battery requirements)
- Bow Steering (hand, cable, wire, wireless)
- Transom steering (tilt, fixed, backtroll)
- Mounting footprint or transom width
- Metal shaft VS Composite
- Integrated sonar or not
- Auto Pilot or not
- Budget, which may elliminate allot of wants
Related things to think about/consider:
- What size batteries (reserve needed)
- Where will the batteries be located?
- Wiring size and length, including circuit breaker, plugs, and switches
- Marine charger
papamike
I have owned both at present time I own 3 minnkotas. I just got the power drive for verticle jigging and absolutley think its great no push pull cable steering just touch the button and go or turn very nice.
capt sam
Master Chief Petty Officer
I've owned several of both models, I would have to say overall MK was better but you really can't go wrong with either of them.
BIGcarpy50
thanks yeah i figured they were very similar it just seems that all the new boats have MK and it's the only brand i see in the local outdoor stores. I think i am going with a MOTOR GUIDE cause i like the Cable steer, and they are about 10% less for same # and transom length
