MotorHead question
delta1
I just checked the timing on my 93 merc 4.3 and if I am correct it was off by 2 degrees. Question one is, will 2 degrees make a noticeable difference?
Second question, Am I correct in assuming the timing tab marks are such: big notch (valley) is the 0 degree and then the first point is 2 degrees and next valley is 4 degrees.......so on.
Thanks,
Paul
Don S
Re: MotorHead question
At idle, while setting it, you might notice a 2? change. But nothing in operation.
Thanks,
Paul
Ayuh,...... Just by your statement,... You're atleast 4? Out......
4? retarded will cause a loss of Power........
4? advanced can cause Detonation.........
You'd better get it Right.........
