Moulding for 1997 Cajun FishMaster
swade28
I am looking to re-carpet my boat. I was wondering where i could find the rubber moulding that goes around the railing of the boat. Also it seems as if you just unbend the aluminum studs under the rail to get it off. Is this easy to take off and put back on? What am i getting in to here? Thanks, Scotty
prockvoan
Re: Moulding for 1997 Cajun FishMaster
There are screws that go thru the rubber railing in the center.Those clips is were the screws screw to.Don't bend them,you will need them or buy more,not cheap.Check West Marine,but I'm sure if you shop around you could find it at a better price for railing is not cheap.
swade28
Ok. I started to pull some of the rubber insert out of the railing to look at it. I only looked at a couple and they didnt appear to have screws in them. Is it possible that only some and not all have screws attaching the railing? Thanks, Scotty
jmccall001
check with my bank - west marine, look at their catalog. they have rub rails and the inserts for the rub rail. might find just what you need
