mounting small surface area metal plate to thin fiberglass console for fish finder
x_david_x
I am looking for advice on mounting a small rectangular piece of metal to thin fiberglass/plastic. I am concerned about the mount point breaking if the item on the mount is bumped into. Details below...
A couple years ago, I mounted my fish finder on my pontoon console. I wanted to have the fish finder high enough that I could pivot it and see it when I was in front of the console. Therefore, I built an open, rectangular box out of synthetic home deck boards (pictures below). I think I glued them together with 3M 5200 or 4200 sealant. I also glued the base of the box to the console with the same sealant. The sealant didn't hold the box together a year later (smooth fake-wood), so I gorilla glued the pieces together. The base is still on with the 5200/4200.
Here is how it looks now:
fishfinder_mount_port_side.jpgfishfinder_mount_starboard_side.jpgfishfinder_mount_stern_side.jpg
Now that I've used the fish finder in this location and I'm happy with it being there, I am planning to replace the crude box with a more permanent solution. I plan on mounting the fish finder to the console with a ParkerMount device. With this solution, I can have a multi-jointed mount that will allow complete freedom of location.
ParkerMount with Toughbar Elbow:
The above picture uses a suction mount. The mount I will be using is a permanent mount. It measures 2"x2.5", with 4 bolts holding it in place.
The console appears to be some sort of plastic outside reinforced with thin fiberglass inside. The two layers are probably 1/8" combined. I'm concerned with the leverage of the long arm that the mount point may break if I just bolt the mount through the plastic/fiberglass. I'm looking for recommendations on how to mount it.
My currently considered options are:
1) Put a larger piece of plywood or metal plate on the underside of the console and bolt the mount through the console to the bottom support piece. This should distribute the load more than the small mount and washers.
2) Same as (1), but also put a piece of wood or metal plate on the top side of the console too. The mount could then either be bolted/screwed to the top piece or could be bolted through both top and underside pieces. What this buys me is if something heavy pushes on the mount point from above, it won't break down into the console as easily.
3) Fashion or buy some sort of bracket that will fit onto the aluminum railing to the starboard side of the console and bolt the mount to that bracket.
Thoughts on the above options or other options I haven't considered?
Thanks!
Re: mounting small surface area metal plate to thin fiberglass console for fish finde
Ayuh,... For that location, I'd go with option #1, as big a piece of thin plywood as you can reasonably fit, as a backin' plate...
Or option #3...
x_david_x
Thanks for the feedback, Bond-o. Is there any particular reason you'd go for plywood vs metal?
Woodonglass
I'm thinking I'd see if I could find some scrap 1/4" plate aluminum for the backup plate under the dash. that would be plenty strong espectially if you mounted with a bunch of 3M4200.
lmuss53
I went 6 inches to the right and put the Ram base on my pontoon railing. 2 stainless U bolts through that base will hold it just fine and you'll have no worries about pulling it out or off.
jbcurt00
It's been over a year, Chazz, if they haven't mounted the fishfinder yet, I doubt they will.
The big red banner at the bottom of your browser window should have read:
Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
After being inactive for 90 days, threads should be considered libray books: For research only, and please don't write in them.
Have a great weekend.
