moving 1990 200hp johnson 25 shaft to a 235hp 1985 20 shaft housing...
peacekeeper6
can i do this if i change the exhaust adapter plates on top of the exahust inner tubes? will it then fit? will my 235 electronics work on the 200hp block?
peacekeeper6
Re: moving 1990 200hp johnson 25 shaft to a 235hp 1985 20 shaft housing...
bump.
peacekeeper6
ok i finnally got this 200 running nicely. now my transom currently has a 20" shaft on the top most hole on the plate. if i take my 25" 200 and slap it on the bottom most hole, will this work?
peacekeeper6
i mean we are talking a mere 3 inches below the bottom of the transom.
peacekeeper6
all i ahve to do to do this is change the exuahst housing adapter plate right?
