Moving the filter
DeepCMark58A
1992 Mariner 2 stroke 115 hp. Can I move the fuel filter to the intake side to allow for easier accesss and protect the fuel pump? Wondering it has tolorances for lower intake vaccume vs pressure discharge?
dingbat
Fuel filters are gravity devices. By design, filters are placed on the vacuum side of a pump.
Don't know of any "fuel filter" rated for pressure service.
DeepCMark58A
Well there is one on my 1992 Mariner 115hp motor, it is after the fuel pump and before the carborators.
DeepCMark58A
Mercury part number 35-816296-4. Goes between the fuel pump and the carbs, pressure side of the fuel pump.
boscoe99
Different design philosophy. Yam likes to "pull" fuel from a primary fuel filter. My Mercury EFI pumped it through the primary fuel filter.
Racor fuel filters are rated for up to about 7 psi as I recall for folks that use an electric fuel pump to deliver fuel to a motor.
boscoe99
What is the engine ID or serial number?
DeepCMark58A
I found the fuel filter I need in stock at a marine dealer, now I just need to curse the new filter in place.
dog22
I have 1 of these motors it is very important to have another fuel filter between the tank and the motor That is what I did with my motor because as you found out there is unfiltered fuel going into the pump which can cause a problem with the check valves inside the pump
DeepCMark58A
Yes I did that when I installed the motor on the boat.
Texasmark
Problem with the filter on the inlet of the fuel pump is a condition known as "vapor lock". The fuel pump sucks on the fuel tank causing a partial vacuum /low pressure area. When hot, lowering the pressure on a line full of fuel can cause it to boil filling the line full of gas bubbles not fuel. The engine is starved and quits.
I had a 1971 Chev. station wagon with a 401 big block with a 4 barrel Quadrajet with the mickey mouse tiny filter at the fuel inlet port on the carb......on the pressure side of the mechanical fuel pump.
I thought I would be creative and install a large inline filter between the fuel tank and the fuel pump. Coming home from vacation one hot July afternoon, towing the boat, car full of family and vacation toys....good load.... motoring down the interstate at the speed limit the engine died and forced me to the side of the road.
30ish minutes of sitting by the side of the road with the hood up and family having a fit due to being hot and wanting to get home, I could get it to start and down the road we went (with the AC off) and after several stops like the first one, finally got home.
Guess how long it took me to remove that "great idea filter addition"????? Never had that problem before under the same load and hot day and never had it again.
QBhoy
If you’re keen…you could just install the usual water separating filter unit, commonly installed as an option these days. That sits in line between the tank and the engine. Mounted on the or in the boat.
dingbat
Never said it was, I was not the confused one.
My bad.....considering most motor manufacturers recommend the use of a 10 micron or better fuel filter, a rock and stick collector isn't the first thing that comes to mind when someone says "fuel filter"
