MR drive shift cable
brucec
In process of reassembling MR drive. On the forum there was a comment that the screw at the stern end of shift cable should not be tight but should be able to allow cable to turn and that is what the figure 8 safety wire is for holding the screw without it being tight. Should the cable be able to be pushed through the block? Mine is frozen solid. Wont turn and wont move. I have attached a pic to help show what i am asking about.
Thanks in advance
Bt Doctur
slide must rotate on the cable core, most like you had water in there at some point and got the aluminum mud packed in there. That also will have a bearing on how well reverse happens
brucec
Thanks. Any ideas as to what I can do to free it up and should cable come out of the screw hole
Bt Doctur
thats how the cable is removed, cut the safety wire unscrew the allen and the core comes out the back
brucec
Any ideas as to what can un-seize the cable. I've tried yield and liquid wrench.
Bt Doctur
some heat and penetrating oil maybe but if its old enough ,just replace the shift cable
brucec
Thanks I clamped the cable about a quarter inch from the casting between two blocks of wood. i applied heat and rapped the casting with a tack hammer. I was amazed at how much white powder came out and it finally freed up. The heat did the trick.
Grub54891
At this point, I'd replace the cable. The new cable comes with the aluminum casting, and the hardware up top. You'll be much happier having smooth shifts!
