Re: Muffs and suction
The jug has to be higher than the engine. You need a minimum of 5 gallons to get the job done. Before you start, run the engine for 15 minutes on the garden hose to get it real hot and ensure the thermostat stays open. Don't use RV antifreeze...its made for the sink and toilet. You need marine antifreeze thats formulated to be in an engine block for extended periods of time.
They make a kit to do what you want. Includes a tank, hoses, valves, etc. I'm sure somebody else will chime in real soon - the experts here advise against doing that very thing becuse if you don't do it perfectly right you will leave some water behind and the block will crack.
