Multi Gage Failure
jaylowe
I have a 2005 Larson with a Faria multi gage (RPM, fuel level, volts) that has slowly failed over the last three years. Two years ago the fuel level gage failed high. Last year the rpm gage failed (stuck) at about 3,000 and this year the volt gage indicates about 12.5 volts with the engine running - checked the battery with engine running and its voltage is about 13.4 volts.
Anybody else have problems with this type multi gage? Am I doing something wrong - gages need maintenance like cleaning connectors? I live and use the boat on a fresh water lake. All the other gages work OK. I pulled the fuel sensor and the float was not stuck at the top.
Also I am unable to find a replacement - anybody know of one?
thank you
Jay
Don S
Re: Multi Gage Failure
Most people have problems with those multi gauge units. Mostly because after warranty you have to replace them if no one will fix it, and boat instrument panels don't get wet like boats.
Contact Faria and see if they can fix it for you. https://faria-instruments.com/forms/?form=new
Silvertip
Great Lakes Skipper has bunches of multifunction gauges.
