roscoe
- Oct 30, 2002
- 21,780
I rebuilt my boat a few years ago. Including a complete rewire.
All worked well. Everything is wired correctly, well, except for not to ABCXYZ... boat wiring colors.
This year, installed new sonar units, and they seem to be more sensitive to low voltage (when starting the main motor).
I decided it was time to add a second battery for accessories, and also to save my starting battery for the motor.
This solved my issue with the sonars, but created a new one.
When I wired the boat, I installed a separate fuse/switch for the gauges, as I don't like the dash lit up all the time when fishing or driving at night. I would like to keep this option.
So, the gauges are powered off the ignition switch (house battery), the gauge lights are powered off the fuse panel, the fuse panel is connected to the new "house" battery.
All the gauges have a single ground connection on the back, which grounds the gauge function, AND the light.
The ground wires from the gauges run back to the ground buss next to the fuse panel, and then back to the house battery.
The problem: There is no ground connection back to the starting battery, so the gauges do not work.
If I put a jumper between the main battery and the house battery negative posts, all the gauges function.
? Is it acceptable to have the two battery neg posts connected?
Will it cause and problems or damage ?
Is it a problem to have the gauges and gauge lights grounded to both batteries?
If this is not ok, what are my options?
I really would like to keep the gauge lights.
If need be, I could eliminate the gauge lights
and run a new ground wire back to the main battery, which would be a pain as this is a center console boat, batteries at stern. Could I tie into the ground side of the KILL switch ?
Your insight will be greatly appreciated.
