BlueGhost93
- Oct 15, 2013
- 114
Ok so on this 88 40hp, it came with a newer controller like this one http://mediacdn.shopatron.com/media/mfg/664/product_image/a680604fd9240528b1a98c6914bf7f63.jpg
Now whats happening is I can shift it and it goes in forward gear fine, then I go to put it in reverse and it wont push the cable far enough back... I then try and adjust it under the hood of the motor so the cable is more centered in neutral and then try again. Well it seems like the cable can only be adjusted so one direction will make it into gear but not both...
Could this be because this newer controller doesn't have enough throw and these older outboards had a longer throw in their controls?
And the second issue is the cable seems to be fine but when pushing the controller into full throttle, its really stiff. Cant seem to figure it out.
And thirdly, when put into full throttle the outboard doesn't seem to do much even though I see the carbs are opening (the linkage at least goes to full open). It picks up a little bit of speed but not enough to even get up on plane. Yet in neutral I can get it to rev up really high by hand like it should when in gear. It makes zero sense...
