Muncie Gear Neptune 10A2
JDusza
Ensign
I'm trying to save a Neptune 10A2, c. 1940.
The piston is frozen in the cylinder. I believe from neglect and rust and not from scoring.
The connecting rod and crank are in good shape.
I have the cylinder flooded with PB Blaster, soaking.
Is there anything else I can try to loosen the piston?
It appears the piston is aluminum, the cylinder walls are cast iron, and the piston rings are steel, so I think the rings are stuck to the cylinder.
And, while we're here, is there a source for seals and gaskets, etc.?
Thanks,
J
nwcove
Re: Muncie Gear Neptune 10A2
google doug penn, hes probably the most knowledgeable guy on the continent when it comes to those mighty mites. real good guy.
ronboonville
Not sure about your neptune cylinder configuration but rogersjetboat posted a video when I had same problem, youtube, Maytag Gas Engine junk yard special #4, I also soaked cylinder and piston in automatic trans fluid and acetone for a week. then I made puller like the maytag guy. hope this helps.stuck piston puller 001 (Small).jpgstuck piston puller 002 (Small).jpgstuck piston puller 003 (Small).jpg
