Musky / Northern and chemical response
roscoe
Since I started using SeaFoam gas treatment, I have been catching more musky and northern than ever before. <br /><br />Could it be they are attracted to the chemical residue in the exhaust? Or that it causes them to go into the feeding mode?<br /><br />Do you think it would make a good aftershave, for when I go out "hunting?"<br /><br />Maybe this should be posted in the outboard forum?
gonfishn
Re: Musky / Northern and chemical response
Roscoe you ain't gettn me to bite even on this one. I always thought it was the way you hold your mouth..Better yet your catching more cause you are gettn better..But please Seafoam.. :D . You must not be fishn and the cabin is gettn to ya or you been sniffing some of those fumes..
moderator1
roscoe <br />Admiral <br />Member # 17069 <br /><br /> posted March 15, 2004 06:08 PM <br />--------------------------------------------------------------------------------<br />Since I started using SeaFoam gas treatment, I have been catching more musky and northern than ever before. <br /><br />Could it be they are attracted to the chemical residue in the exhaust? Or that it causes them to go into the feeding mode?<br /><br />Do you think it would make a good aftershave, for when I go out "hunting?"<br /><br />Maybe this should be posted in the fishing forum? <br />--------------------------------------------------------------------------------<br />Posts: 3269 | From: Medford WI | Registered: Oct 2002 | IP: Logged <br /> <br />crazy charlie <br />Admiral <br />Member # 23774 <br /><br /> posted March 15, 2004 06:23 PM <br />--------------------------------------------------------------------------------<br />There are many uses for humans too.It frees sticky rings(any finger),if on a low carb diet it cleans carbs,its a head cleaner for a good clean upper end and a lower end cleaner and lubricant.Just a few of the many uses.Charlie<br /><br />--------------------<br />crazy charlie
moderator1
I deleted your duplicate post in General Outboard. I moved its contents here. I'm not even sure it belongs here. :confused:
roscoe
I guess I need to practice my trolling.<br />Thought a topic that listed musky and seafoam would surely get more responses. :confused: :D
