superharmonix
- Sep 5, 2010
- 140
Hello Johnson experts!
I am stocking up all my maintenance items and just got my manual to match the above engine. There a few things it calls for that I can not find, so I am hoping some of you could point me in the right direction on each of the below.
Manual says to use:
OMC HI-VIS Gear Case lube- capacity 29.1ozs for the Lower Unit.
Anderol 766 to lube starter pinion..
OMC Anti-Corrosion lube for various such as cover latches, tilt tube shaft, swivel bracket fitting, etc.
Johnson Outboard 50:1 lubricant which is BIA certified for service TC-W (water cooled) for the fuel.
OMC Power Tilt/Trim fluid capacity 12.5oz
What I have:
I have some all purpose trim and tilt fluid with various brands on the front, including Johnson for the Tilt N' Trim.
I have some Rotella Grease Heavy Duty Lithium Complex 2 for all the various greasing applications including the trailer bearings.
I have some Quicksilver Marine high performance 90W gear lube for the lower unit.
I am not sure what to use for the starter pinion?
Finally, when comparing what my motor manual says vs. what is available today, am I using the right stuff I noted? If not, what should I be using, and what should I use for the starter pinion? What ios the best type of oil to mix with the gas?
Thanks to my priceless seafarers!
Manual says to use:
What I have:
