My 250 CC resto
roy c
when removing and replacing transum and stingers bulk head ect..
does the hull have to be cradled ? I was wondering if when removing the stringers
will it cause the hull to sag even slightly ?
kcassells
YUp, it is recommended to build a support cradle just for the reason you mentioned. Welcome aboard.
tpenfield
The hull itself has little strength without the stringers and other structure. Usually a bunk trailer along with some bow supports will keep the hull in shape.
Otherwise, a cradle as mentioned.
