My 30hp Johnson(revised question)
Well I found the serial # and Model #<br />Serial # 1396986<br />Model # RDE 18 E<br />I am told it is a 1956 are they right and any ideas on finding a prop
JB
Re: My 30hp Johnson(revised question)
Yep, BA. <br /><br />It is a 1956.<br /><br />Where have you tried to find a prop?
I ended up finding some in Grand Rapids they have new ones for 75 and used for 25-30 gotta get there to get one. Is that the cheapest I'll be able to find one for and should i Go used
Also what would be the fuel to use with this motor and ratio, tuning tips for its use on a Lubbers fiberglass boat
JB
I see no reason not to go for a used prop, BA. I think I would buy 2. One for a spare.<br /><br />Use a 24:1 mix. That is one quart of TCW-3 Outboard oil to 6 gallons of unleaded regular, alcohol-free gasoline.<br /><br />Good luck. :)
Yepblaze
There has been a bunch of new old stock propellers on ebay lately for the old OMC's
where can I find a gas tank for this motor its one of the old two line pressurized
D
DJ
Guest
They crop up quite often on e-bay.
D
DJ
Guest
I believe you can convert it to a single hose.<br /><br />Use the search feature on this board with these parameters.<br /><br />1. Search words: "fuel tank conversion".<br /><br />2. Section: Outboards.<br /><br />3. Date: Any<br /><br />There will be plenty to read on the subject.
SCO
I've got one of these a '58( mines an 18hp). I found a new stock prop at my local omc dealer. You can also get new double fuel line and orings for the connectors. I too have seen a lot of these tanks on ebay. Good luck.
Problem the male connector on the engine is gone where can I get antoher and how much is it gonna cost me
