Well you guys helped me a lof in my schooling on Merc's, thanks. It is a s/n 4848057.<br />Once I get carb cleaner it will fire, and also when is hot. One engine cools down it won'
<br />When it fires with the help of the cleaner, and it runs, I notice it misses at times when I increase speed.<br />I replaced rectifier, carb kits, fuel pump kit, replaced the stator for a used one, I Get tach and volt gage readings, replaced ignition switch, and plugs,disconnected kill switch wire,checked ignition wires for continuity, replaced two; replaced the coil for a new one. Checked the mercury switch to be okay; I get spark on all six.<br />I replaced the switchbox for a used one from the net. No change. Is there a way to check the switch box?<br />It has three wires: black, tan and brown for the triger on one side.<br />On the other side has the red, white and green.<br />The green goes to the ground coil, red for power and white from somewhere out of the plug inside the bottom cowling.<br />I set up all of the iddle timing fro 4 - 6 degrees., carburators throttle closed. Where did I miss ?<br />Do I need a New switch box ? or a triger ?<br />Thanks for your response.
